Indesit wixe127(uk) (tev)
  • #40895
    BURNIE
    Help if poss please
    led display reads dENO. is this some type of fault code or maybe a problem with control module. i have run tests with avo on most all of the components but all seem ok. would be grateful for any advice
    thanks
    burnie
    #267944
    Re: Indesit wixe127(uk) (tev)
    Its DEMO or demonstration mode.
    Not sure how to clear it on recent Indesit though. 😥
    helo_75
    its on pg 10 of the instruction manual
    anyway
    Demo Mode
    If the machine is on Demo mode ‘D on’ will be displayed and the machine will NOT function.
    To reset the machine for normal use:·
    Turn the power off at the wall.
    Push in and hold down the Start/Stop and the Start/Reset
    buttons, while still holding down, turn the machine on at the
    wall.
    ‘D off’ will be displayed and the machine will function
    normally.
    hope this helps
    #267946
    BURNIE
    many thanks for help will try and let you know outcome i was a little confused because of the spelling in the led display.
    many thanks again
    burnie
