Indesit wixl 143
  • #73056
    winker
    Had the classic all lights flashing which settles after a few seconds to allow programme selection and starting.Replaced the main control board…cured.Now after starting cycle and after some time has lapsed the easycare light starts flashing (n0. 3 light from the left.)Error codes suggest jammed motor or taCHO
    fault.Checkedbrushgear and tacho security and the magnet.The connections appear ok to the motor and module…so a bit stuck.
    Seem to remember on the diagnostic visit this light flashing but assumed it would disappear on panel replacement.
    Two questions
    any ideas
    what is the meter reading for the resistance of the tacho coil
    this one is 119ohms which seems low for a fine wire coil ?
    #386298
    Criscold
    Re: Indesit wixl 143
    Found the following
    – Check motor not seized;
    – Check edge connector J9 has secure connections on
    module;
    – Remove edge connector J9 on module check wiring and
    contacts at position 1 and 2 on connector J9;
    – Check tacho generator windings and that there is an
    impedance value of between 115 and 170 ? on the wiring
    connector J9 between pins 1 and 2;
    Colin
