Indesit WIXL 143 Door frame.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIXL 143 Door frame.
  • #43361
    Andystu
    Hi Chaps. The Indesit WIXL 143 door inner frame, does anyone know if they can be purchased seperately or is it a complete door assembly?. Seems a bit of a travesty if thats the case as the door comes apart so easily!!
    Andy Stu
    #276956
    Re: Indesit WIXL 143 Door frame.
    Did one on an Indesit this morning, whole darned door when there was just tiny piece of plastic broken off the outer door trim. :rolls:
    Along with the sealed tubs it won’t be long before you click on an Indesit parts diagram and find there is just one number. 😥
    #276957
    Andystu
    You’re not wrong there mate!!!, Espescially as just googleing WIXL 143 it comes up with a complete machine for £193. Throw away society or what?. With Indesit call out charge being bets part of £90 no doubt and complete door retail @ £35!!! New door at £125 or new machine at £195. NO BRAINER>>
    Cheers anyway, figured as much!!. No doubt Hotpoint will be much the same I suppose.
    Andy Stu
    #276958
    helo_75
    is it just the bit where the pin is held in place.. i had one today, just made a hole through the back, and used a cable tie to secure the pin…
    not had one back yet…
    #276959
    Madmac
    Ditto. Used a cable tie on 3 so far. seems to work well enough, i DO love trying to beat the system though 😯
    #276960
    helo_75
    sometimes u just gotta
    #276961
    Andystu
    Thanks for the tip boys!, I’ll give it a go tomorrow, see how we fare!!!.
    Andy Stu
    #276962
    roy1
    The cable tie is stronger than the origional plastic.
    #276963
    Madmac
    Wet bog paper is stronger than Indesit plastic ! :rolls:
