Indesit WIXL 143S W/Machine
  • #59998
    mike412
    I was lucky enough to have the opportunity to look at one of these today.
    On switching on, the interlock energises and locks the door and the wash led comes on, but not the door locked led. Machine does nowt else.
    I tried a new interlock but made no difference. Are we looking at a new control board here?
    Many thanks in anticipation,
    Mike.
    #340374
    suedehead1
    Re: Indesit WIXL 143S W/Machine
    did you check the brushes?
    #340375
    mike412
    No, didnt check motor. Would that cause the door lock LED to not illuminate?
    Thanks, Mike.
    #340376
    allan73
    It has on some of the Hpt/Ind m/c’s I’ve worked on.
    #340377
    mike412 wrote:No, didnt check motor. Would that cause the door lock LED to not illuminate?
    Once the door locks the programme ‘self-checks’ the various internal components like heater, pump, valves and, likely as not in your case, the motor. If any are at fault the machine takes the hump and doesn’t want to play no more! 😥
    #340378
    mike412
    Thanks for your help gentlemen. I will take a look, poke and prod and see what I can find.
    Regards, Mike.
    #340379
    mike412 wrote:I was lucky enough to have the opportunity to look at one of these today.
    :rotfl: Like the dry humour.
    Mike.
