Re: indesit WIXL123
Best to give the slow flashing light by number from left, is it light 1?
If so then it is supposed to signify a motor triac fault.
It could be a fault on the main PCB, loose wiring connections, worn motor brushes etc.
If you spend some time looking round this forum you will soon realise that the electronics in Indesit machines are one of the most unreliable used on the market today.
Does it appear to drain correctly?
PS. You appear to have had a lot of washing machines in the past three years, are you in the trade. 😕
