Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WIXL123 not filling
- This topic has 10 replies, 3 voices, and was last updated 11 years, 11 months ago by
sniktaw.
April 23, 2014 at 2:56 pm #80411
sniktaw
ParticipantHi,
any help greatly appreciated. Thus far have tried:
inlet valves reading ~1.2Mohms therefore not OC
pressure switch contacts all OC until I blow into it the close
pressure switch pipe not blocked
filter not blocked
if left long enough then the Stain Removal, Easy Iron and Door lock lights flash continuously and the pump chugs continuously. That’s function control light 2 & 3 and door lock ;o) Only way to stop this is turn off electric at wall.
many thanks for any help,
Daz
April 23, 2014 at 3:12 pm #412759Martin
ParticipantRe: Indesit WIXL123 not filling
Have you by any chance checked the state of the motor brushes?
April 23, 2014 at 4:20 pm #412760sniktaw
Nope Martin ;o)
Happy to do so. Can you explain the logic? Why if not filling with water might it be an issue with the brushes?
ta,
Daz
April 23, 2014 at 4:24 pm #412761Martin
It’s an Indesit, so logical thinking goes out the window. 😉
April 23, 2014 at 4:57 pm #412762sniktaw
Nuff said
;o)
April 24, 2014 at 9:53 am #412763sniktaw
OK, checked the brushes and there’s at least 1″ remaining on each of them.
Any other ideas?
much appreciated
Daz
April 24, 2014 at 10:25 am #412764iadom
ModeratorRe: Indesit WIXL123 not filling
Lights 2&3 is F06, fault is supposed to be door lock related, door lock, wiring, pcb connections or even a pcb fault.
April 24, 2014 at 10:42 am #412765sniktaw
thanks for the quick response iadom ;o)
I’ll check the connections (that I can). I do know that the lock works or at least, the light goes out and the door will not open. Then, after powering off the door lock clicks and door can be opened.
Daz
April 24, 2014 at 1:03 pm #412766iadom
I did say ‘supposed’ to be. 🙁
April 24, 2014 at 1:08 pm #412767sniktaw
sorry, wasn’t a criticism. Simply wanted to give all of the facts – like I should have done at the outset – doh!
;o)
Daz
April 24, 2014 at 3:17 pm #412768iadom
sniktaw wrote:sorry, wasn’t a criticism. Simply wanted to give all of the facts – like I should have done at the outset – doh!
;o)
Daz
No problem, I didn’t take it as a criticism, I was just pointing out that Indesit electronics are about the flakiest on the market and throw up all sorts of spurious codes. It is well worth giving the whole of the machine a once over with a megger to check for insulation leaks, especially the heater and motor. -
