Hi All
My Indesit WIXL123, 1200 smells of very warm (not hot) rubber during and after a wash.
The dispenser drawer is not the cause and it seems to be happening during fast drum portions of the cycle. Definitely noticeable when I open the door after a wash.
Additionally I have halved the load amount and the smell seems not so noticeable suggesting that the weight of wet washing may be causing something to ‘rub’?
Before I usually put approx 3 bath sheets and a couple of face towels equivalent in per wash (or similar), but am doing lighter loads now just in case. I haven’t overloaded the machine previously nor do I let wet washing sit inside for any amount of time.
I am using a standard programme (9) for around 40 mins at 40dg. I also put detergent into the dispenser, not the drum.
I would be able to do some minor repairs with a little guidance, but at present I don’t know if I’m looking at bearings, brushes or belts ( & wouldn’t know what each is for yet)!
I can learn which is which and poss replace a part myself with a little instruction but electrics are beyond me!
Thank you in advance if you can help, I’m really grateful!
Have a good day!
