Indesit WIXL123UK/Y second & third LEDs from left flashi
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIXL123UK/Y second & third LEDs from left flashi
  • #57626
    Bernie
    Indesit WIXL123UK/Y second & third LEDs from left flashing
    This machine has an intermittent fault, it has played up twice in the last two weeks although it has had a problem for over a month now. This time the second & third LEDs (stain removal & easy iron) were flashing along with the door lock. They use the machine at night so find it like this when they get up.
    I cannot find any fault code for this model the only one I could find said that it was an F6 and this is not used!
    I sat and watched it through a 30 deg program 3 and it worked fine. I did go to this machine mid August and Posted the fault I was getting then (Posted Aug 19, 2010) Martin suggested it might be “mains power failure? Wall socket? Mains lead/suppressor?” I haven’t been able to get back as the customer has been away, do you know part number for the mains lead/suppressor as I can’t find it.
    Many thanks for looking any suggestions please
    Bernie
    #331764
    Re: Indesit WIXL123UK/Y second & third LEDs from left fl
    C00259581 mains cable/suppressor.
    F06..Door Lock does not Open or Close: Check door lock, wiring
    connections at door lock and J004.
    #331765
    Bernie
    Thanks for that iadom
    On my other post about this machine baron said “Could you check “door lock” contact ( between “L” & “C”) and related wires”
    It might be to do with door lock or wiring
    Bernie
