Indesit WIXL133 int door lock indicator /off
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIXL133 int door lock indicator /off
  • #64760
    mjw1208
    Got a INDESIT wixl133 with a strange intermittent fault , customer sets machine going ok on any programme but then machine intermittenly stops and door lock light goes off and the then strange arcing type sound and back into life again all within 3-5 seconds. We have replaced the door lock, checked and replaced motor carbons etc but fault persists have had pcb out and relays are clicking when fault appears .Sent pcb to EMW and returned no fault found fault still apparent does anyone have any suggestions where to look next think poss front pcb or wiring ?
    #357983
    Re: Indesit WIXL133 int door lock indicator /off
    Motor plug connections are very weak on these, I have cut them of and fitted old RAST type plugs to several Hotpoint machines with the same set up and door not locking faults.
    #357984
    mjw1208
    Rewired motor plug connections and door lock connector with individual spade connectors and fault still persists ,any further suggestions anyone ?
    #357985
    Mains plug/socket, mains filter?????
    #357986
    Allsorts
    This is a common fault on this model when fitted with the Arcadia board.
    #357987
    mjw1208
    Replaced the mains filter and tried on spin program seems all ok ,but when tried on a wash program fault re-appears !!!!
    #357988
    mjw1208
    Fault located to dry joint(s) on on/off switch contacts on front pcb ,connections looked ok but once resoldered and machine ran over several days fault cleared
