Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WIXL143 Flashing LEDs
- This topic has 10 replies, 4 voices, and was last updated 12 years, 7 months ago by
romashka.
September 12, 2013 at 2:04 pm #77107
romashka
ParticipantMy washing machine (Indesit WIXL143) has stopped working and the lights are flashing as follows
Function buttons, top row from left to right
1 – Delay Timer – flashing
2 – Stain Removal – flashing
3 – Easy Iron – flashing
4 – Extra Rinse – flashing
5 – Door lock – flashingTo the left of these lights there are also a set of four vertical lights as follows. Top to Bottom
1 – Prewash (2h) – off
2 – Wash (4h) – off
3 – Rinse (6h) – off
4 – Spin Cycle (9h) – flashingI understand these indicate some error code but I can’t figure out what lights correspond to what error. Does anyone know what these flashing lights mean or any suggestions on how to fix the machine?
September 12, 2013 at 3:35 pm #401037iadom
ModeratorRe: Indesit WIXL143 Flashing LEDs
That is not an error code, are the top row of lights including the door lock light all flashing rapidly at the same speed?
Sent from my iPad using Tapatalk HDSeptember 12, 2013 at 10:00 pm #401038romashka
ParticipantRe: Indesit WIXL143 Flashing LEDs
Yes all the ‘flashing lights’ are flashing rapidly at the same speed. Also the on/off button doesn’t do anything. The only way to power off is to disconnect the mains supply.
September 12, 2013 at 11:07 pm #401039iadom
That is a known fault on the main circuit board, a capacitor has failed.
September 13, 2013 at 10:53 am #401040romashka
Thanks iadom. I guess that means I need an engineer to fix it 🙁
September 13, 2013 at 12:32 pm #401041iadom
Unless you a good with a soldering iron then yes, it should not need a complete new pcb unless you are very unlucky.
Sent from my iPad using Tapatalk HDSeptember 13, 2013 at 1:08 pm #401042romashka
Thanks again iadom for your help. I’m not good with a soldering iron (but not a complete amateur). I may have a look and see if it looks like I can replace the capacitor.
October 9, 2016 at 7:28 pm #401043Mpassmore
Hi guys i wonder if any1 could help me with my problem with my indesit wixl143 the delay timer light – 1 is constantly flashing on and off slowly with the door lock also flashing but very fast could anyone give me any idea what the problem could be thanks very much
October 9, 2016 at 8:10 pm #401044iadom
Light 1 flashing is ‘supposed’ to be F01, again it is supposed to signify a short circuit motor triac on the main pcb.
It can be anything from a faulty main motor or power pcb to worn motor brushes or poor motor wiring connections.
October 9, 2016 at 8:52 pm #401045Mpassmore
Thanks for the quick reply im clueless with things like this ill check the plug wiring and then if thats not the problem ill have to get an engineer out thanks again
July 23, 2017 at 10:55 am #401046mrtricky78
Hi, did you resolve this issue? Mines just started doing the same. Thanks
