indesit wixl163uk
  • #52166
    randomrob
    Hi hust wondered what you thought about this fault with the indesit wixl163uk
    s/n 710137297
    The machine is not spinning properly, it agitates ok but never gets up into the full spin. I have checked the brushes and cleared the pressure system of blockages. It worked for 1 cycle then went back to not working. I think it is the pressure switch getting stuck but just wanted a second opinion. It also brings up a fault code on a spin programme of lights 3 and 4 (left to right) which i thought was a thermister prob?
    any advice will be gratefully received.
    thanks
    rob
    #310808
    helo_75
    light 3 and 4 is f10
    which indeed is ‘not sensing pressure switch’
    now, that could be a faulty switch.or a faulty pcb
    i know what my moneys on, but id first check the pcb connections where the pressure switch connects
    power off off course
    #310809
    randomrob
    Re: indesit wixl163uk
    thanks for the quick reply, i think the switch is about 12 quid anyway so will check the connections and order a switch and see what happens
    rob
