indesit wixxe127 – F05
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit wixxe127 – F05
  • #71622
    broadpaws
    Hello all,
    We have F05 error code coem up so its not emptying the water, we have taken teh filter off, no blockages, adn then set it to a spin only programme and the pump is spinning, any other places I should check for blockages etc?
    thanks
    #381677
    Muv
    Re: indesit wixxe127 – F05
    Have you checked the waste pipe outlet under the sink? If you can take the pipe off, then set machine to drain.. Whiks holding pipe in to a bowl,you will then to see what, if any,flow of water you have leavin the machine.
    broadpaws
    hi martin, we have checked th washing machine (grey) outlet pipe all clear, our washing machine is located in the utility room so we have one ubend pipe then straight outside and all is clear.
    #381679
    Muv
    You may have a blockage in the tub hose (large hise leading from the base of the tub, and entering the pump)
    Also check that the impellor of the pump is firmy attached. This may be spinning when no water present, but it may actually be loose..
    broadpaws
    hi martin,
    before your last reply it did a quick 30 minute cycle successfully (empty load) so put a load on for a 112 minute cycle and f05 near the end again, so have emptied machine and checked pump again whilst running a spin cycle and it would seem that this time the pump was stuck only when i touched the fins did it start spinning – any ideas?? Last time when we did above the pump was running – so do you think we could need a new pump 🙁
    #381681
    Muv
    With the power off at the wall.. Put your finger in and poke around the inside the pump moving the fins of impellor as you do so….you may find somthing that may be intermittently fouling it ….
    If not its time for a new pump
    broadpaws
    Thanks martin, can I ask do you know what sort of price that would be fitted? Would it be better/moreeffective fro a new machine?= rather than a repair?
    #381683
    broadpaws
    Hi we have had a dig around, cannot find anything, but as you turn the spindle around it feels like its sprung loaded? ie there is a build up of resisitance for 3/4 of a turn and then it goes loose, and that happens on very rotation in both directions – any ideas…
    #381684
    madangler1
    if there is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} nothing jamming it then it sounds like the pump is gone, cheap part to replace and relatively easy if you relatively competent,
    #381685
    Muv
    As above reply.. Also resistance is mormal when turning..
    M
