Indesit WIXXE167S
  • #79996
    Bebbspoke
    Machine stopped half way through cycle – Fault code F-05
    Attempted to restart – motor audibly rotating but no movement.
    Door is LOCKED; – machine is full of half washed wet clothes now inaccessible… suggestions, please
    #411293
    Re: Indesit WIXXE167S
    F-05 is pressure switch stuck on full.
    Usually caused by a pump filter blockage. The pump filter, bottom right needs inspecting. Access by removing lower, plastic kickstrip panel.
    #411294
    Bebbspoke
    Thank you iadom – your comment appears correct and relevant. – Filter has been cleaned and flushed… may still be crud in the drum to pump line but seems ok now, thanks.
    Better than paying out all three testicles to a “service engineer”!
    #411295
    Bebbspoke wrote:Better than paying out all three testicles to a “service engineer”!
    Heaven forbid that we engineers should ever demand such an extreme form of payment for our services eh Jim? 🙁
    #411296
    Certainly not, I would expect an arm and both legs minimum. 😉
