Eeprom is a bit tricky. If it has an FHP motor it is 1605709.
If it has a CESET motor then it should be a C00195966 as long as the CESET motor has a 52mm field coil stack measured across the laminations.
Unfortunately, Partfinder does not list the eeprom if it has the 45 mm field coil, that has a different eeprom file apparently. 😕
