Indesit WIXXW127 F05
  • #77890
    spanner51
    I went to this washing machine showing an error code F05. I thought an easy fix of a blocked pump, but no the pump was OK.
    The next thing to check is the pressure chamber, BUT the pressure chamber is moulded into the tub. I squirted some water through the pressure hose with a syringe, which cleared it a bit.
    Question is how else am I supposed to clean it? Perhaps the only cure is to replace the welded tub? Any comments appreiciated
    Graham
    #403764
    spanner51
    Re: Indesit WIXXW127 F05
    Sorry the model should read WIXXE 127. Thanks
    #403765
    spanner51 wrote:I squirted some water through the pressure hose with a syringe, which cleared it a bit. Question is how else am I supposed to clean it?
    A bowl of near boiling hot water thrown into the drum, then use the syphon for the ultimate Indesit style blow job! 😉
