Been to the above, timer turns after about 4 mins and does two flashes. The fault codes in our list suggest jammed motor or tacho u/s. Problem is for the few minutes is does run the motor behaves perfectly. Maybe check the brushes or something but its going to be ‘an hour getting it out’ type of job. (Don’t you love these fitted kitchens when the new floor is higher than the feet!)
Just wondered if anyone has had the same fault.
Regards
Paul.
