INDESIT WM12X
  • #69639
    blueboy77777
    M/c stops on wash cycle and then dial stats to click around. i noticed that the fabric conditioner is still in tray.i have reset the reset programme and then put m/c onto spin cycle this results in a a gurgling sound which echos via sink plughole and the m/c makes a buzzing sound. after 4 or 5 mins the m/c stats to spin. for the last few weeks a small amount of foul smelling water has coming up into kitchen sink.
    #375454
    INDESIT WM12X
    The drain coupling under your sink is blocked!
    #375455
    blueboy77777
    Re: INDESIT WM12X
    thanks martin drain coupling under sink was blocked but still have previous problem. ie m/c still stops on wash cyle then dial clicks around. after resetting dial programme to spin and removing washing later on there is a small amount of smelly water left in m/c which i have had to remove via valve/plug at front of m/c.
    #375456
    INDESIT WM12X
    Soapy water gets smelly very quickly (within a few short hours) so I wouldn’t read much into that. I’m assuming now you’ve cleared the blockage and the machine drains out OK or is the dial clicking round preventing that from happening?
    Next question: When the dial clicks around, count the number of flashes the red light shows. (a series of rapid flashes followed by a seconds pause before repeating the number over and over whilst the dial is moving)…?
    #375457
    blueboy77777
    Re: INDESIT WM12X
    monday evening m/c worked fine? no’3 progamme staight through to spin etc = great no dial clicking. water still came up into sink. today wednesday opened m/c door to find 2″ of dirty water in drum. put m/c onto spin and drained water away – still part of the water came up into sink. all pipes are cleaned/ un blocked as is pipe coming from pump to u bend under sink.
    #375458
    INDESIT WM12X
    blueboy77777 wrote:put m/c onto spin and drained water away – still part of the water came up into sink.
    It’s obvious from that statement that your sink drain (going outside) needs clearing then. I bet there’s years of fat deposits, tea leaves and any amount of gunge blocking those old pipes!
    #375459
    bryan-206
    INDESIT WM12X
    Water into sink only means one thing. Your plumbing is restricted/blocked.
    I am here: http://tapatalk.com/map.php?jj5olt
    Life’s a bitch ain’t it!
