Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit WM12X Door seal clamp
- This topic has 8 replies, 4 voices, and was last updated 12 years, 12 months ago by
Bernie.
April 10, 2013 at 10:55 am #74958
Bernie
ParticipantThe door seal on this machine has a wire & hook fixing, which from my last time of trying to fit it back was not easy to say the least.
Would anybody know if you can fit the spring type part no. C00092155
BernieApril 10, 2013 at 2:27 pm #393383iadom
ModeratorRe: Indesit WM12X Door seal clamp
I did that on the last one I and have had no comeback.
April 10, 2013 at 3:40 pm #393384Bernie
ParticipantRe: Indesit WM12X Door seal clamp
Thanks for the quick reply there are two door seals listed which did you use?
C00093345 standard seal with spring clamp
C00064545 wire hook version seal (I guess this is what is on there)
Will either of them fit this machine?thanks
BernieApril 10, 2013 at 6:51 pm #393385iadom
TBH the last one I did was on a built in Hotpoint with the same clamp, used the correct seal and if my memory is correct I used a Zanussi spring clamp, a little bit tighter than the Indesit one.
I have heard of people using a plastic cable tie to hold the two ends of the wire clamp close together giving you two hands to try and get the clamp back on,still a typically stupid piece of Indesit design. :rolls:
April 10, 2013 at 11:26 pm #393386cornwell40
I have a long nose/ long handle pair of pliers which I’ve bent over the ends of the nose 90 deg. Bit of a fiddle but it’s fairly straight forward bringing the ends together. But yep, what a loopy design it is.
April 11, 2013 at 7:52 am #393387Bernie
The 90deg long nose pliers is what I ended up using, but I had to go back after I borrowed them from a college still not very easy. I will give the spring clamp a try.
Thanks for all you replys
BernieApril 11, 2013 at 8:22 am #393388madangler1
There is a trick on these , put a small cable tie though the holes and pull it tight this holds it in place enough for you to clamp it up with pointed pliers
April 11, 2013 at 9:35 am #393389iadom
Is there an echo in here? 😉
Still a bloody stupid design. :rolls:
April 11, 2013 at 11:46 am #393390madangler1
Sorry missed that lol
