No motor action on wash or spin. Checked motor/brushes,module looks ok.Then blew into pressure switch,after which motor worked! Tried several times on wash & spin ok.Next attempt,no motor again! Again activated pressure switch,then motor worked.
Suspect contacts in switch burnt,but would this cause a complete loss of motor action?Could also be a timer fault as this machine is quite old.
