Indesits Partfinder
Home Forums General Trade Forum Indesits Partfinder
  • #17278
    johnnyhoz
    My partfinder has just expired and due to lack of work at the moment £50.00 is a lot of money for me.
    Does anyone no how I could continue using the version I’ve got without upgrading or renewing it
    John
    #173598
    Re: Indesits Partfinder
    I don’t know of any way that this can be done, although in theory it should be possible. However if anyone does, please use e-mail or PM to discuss rather than the forum. 😉
    #173599
    i am still running an old copy with no probs but this was before partfind and fastrak discs were combined
    have date set in 2001 and the disks cant tell. not had a later disk to experiment with but may risk £50 in near future
    johnnyhoz
    Thanks for the advice
    John
    #173601
    squadman
    I doubt that this is possible due to the fact that once Partfinders installed it writes a script file into your system and you then need to activate online with Merloni. As I understand it there activation process then compares the script file with there system date and time and updates the file on your system. If the two fail to corresponde I believe activation fails.
    However I am just about to update my Partfinder and will try this and report back.
    I too hate paying out ! cause I run it on our server network as well as laptops.
    #173602
    not sure if this would work but if you do not let it expire but reset the date before it does see what happens
    ie put it back a week each day to see if prog reacts
    whitevanman
    electrofix wrote:not sure if this would work but if you do not let it expire but reset the date before it does see what happens
    installed norton and had to reformat hd on pc , reloaded it and got an extra 6 months free perhaps it will work with partsfinder, just a thought/experience
    wayne
    #173604
    d-ray
    When partfinder is activated it writes to the registry (DO NOT GO INTO THE REG EDITOR UNLESS YOU KNOW WHAT YOU ARE DOING) in location [HKEY_LOCAL_MACHINESOFTWAREJVF Systems LtdPartfinder II] and the date is in the lic file in hex.
    If you put the date back you can stop other programs from working
    John
