Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesits spinning during wash
- This topic has 8 replies, 7 voices, and was last updated 19 years, 6 months ago by
Ray9500.
October 2, 2006 at 9:04 am #21324
Ray9500
ParticipantAre these supposed to do this?, i have seen so many of these later machines do this while i’ve been testing them 😕
I have even had a WD12 spinning during the drying cycle for a short time before returning to normal.
Any suggestions?Regards
RayOctober 2, 2006 at 9:08 am #190447Simon46
ParticipantRe: Indesits spinning during wash
Wool wash goes fast at the beginning after fill.
S.
October 2, 2006 at 10:02 am #190448iadom
ModeratorRe: Indesits spinning during wash
This ‘speed wash’ has been used for years on some machines. I believe Indesit were given an award for their effort. Sad really when you think that the old Hoover, Softwave,New wave machines did this many years before.
Spin in the drying cycle is also a normal part of the programme on those machines. If you change a hybrid control unit on the last of the WM based Hotpoint washer dryers the new unit comes with instructions to advise the customer of the spin on tumble dry action.
Throws you a little when you see it for the first time though. 😀
October 2, 2006 at 12:38 pm #190449Ray9500
Cripes!
at least refitting the belt is easier than changing the module 😀
RayOctober 2, 2006 at 12:48 pm #190450Martin
Ray9500 wrote:at least refitting the belt is easier than changing the module
If the fault was just that the belt came off it’s best to change it as it will surely happen again as it’s one of those s-t-r-e-t-c-h belts. 😉
October 2, 2006 at 4:45 pm #190451Phidom
Yes, I’m amazed it doesn’t overload the motors, spinning fast with water in. I suppose old Hotpoints always used to do it at the start of the spin though, before they had time to drain much. 😕
October 2, 2006 at 4:57 pm #190452iadom
To be honest, its hardly a spin, the ‘surge’ wash on my WMA63 is 90 rpm.
October 2, 2006 at 8:29 pm #190453cab
hi interesting post, have noticed the fagor 2fu-3611 does th same at the start of cycle thought it was an electronic fault! 😯
cab
October 2, 2006 at 8:43 pm #190454Penguin45
On the Indesit/Ariston versions, it doesn’t do it until after the heat sequence is finished -useful if checking temperature problems.
Chris. -
