indest dDVKIXUK, trips out the house mcb
Home Forums Public Support Forums Help And Support Dishwasher Help Forum indest dDVKIXUK, trips out the house mcb
  • #59315
    lambrettaman
    Hi, As with most newbies, i have Googled my issue and your site has come up. My dishwasher has tripped out the mcb for the kitchen tonight as it was nearing the end of a wash cycle. opened the door to check for the cause but found nothing untoward. Now just sitting with water in until daylight when I will have a look. Another site had a similar fault (dated 06) and thought the element could be the cause. So this was going to be my first check. Any other suggestions?
    cheers
    #337673
    Re: indest dDVKIXUK, trips out the house mcb
    Well you could give us the correct model number for a start. 😉
    dDVKIXUK is not a recognised model number. You wouldn’t like to hear most of our other suggestions. :rolls:
    I’ll bet you would know what an Li150 was though. 🙂
    #337674
    lambrettaman
    Didn’t read it before I sent it. Should be DV62 it says on the owners manual and the door label reads
    DV 62 K IX UK.
    Still got an Li 125.
    #337675
    The only way forward is to unplug the machine and test all components with a suitable megger or multimeter.
    Your machine could have either the internal tube type element or the ‘L’ shaped element that you can see inside the tub.
    Heating element is always a good place to start, access from underneath. Look for signs of leakage and water damage around the main circulation pump as well.
    My first ever set of wheels was a new Li150, reg GBU622D. 1966 was a good year for another reason, can’t think what right now. 😉
    it was unusal in that it had white side panels and mid blue body, plus the usual lights, mirrors, chrome crash bars etc. 😳
    #337676
    lambrettaman
    WOW, loads of room to work. had it running yesterday and haven’t found the fault yet. I can see where a small amount of water has previously been but cannot see the entry point. Haven’t got a megger here so just checked for earth faults and continuity. Will have to wait untill next time.
    Had a 64 mk2 lambretta but sold it have still got a 1963 mk3 with all lights, mirrors, spare wheel carrier and crashbars. Also a fully chromed and moded vespa.
    #337677
    Indesit dishwashers in particular a prone to oversoaping when used with combination tablets. Its better to use separate detergent, rinse aid and salt ( if required) or the Fairy Active Bursts or whatever they call them now.
