Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indiset IWB 71250
- This topic has 8 replies, 2 voices, and was last updated 10 years, 4 months ago by
Deeker.
December 9, 2015 at 11:08 pm #86984
Deeker
ParticipantStops half way through its cycle with all lights flashing
Thought it would be one of the capacitors, but all look good to me
Any thoughts gents ?
Thanks, any help greatly appreciatedDecember 10, 2015 at 8:44 am #433583iadom
ModeratorRe: Indiset IWB 71250
Are you certain that ALL the lights are flashing, error codes on this machine flash all of the top row but keep a combination of the right hand vertical lights on steady, those lights are the error code.
December 10, 2015 at 12:29 pm #433584Deeker
ParticipantRe: Indiset IWB 71250
Sorry, it’s not getting past the spin mode
Machine is still full of waterDecember 10, 2015 at 1:21 pm #433585iadom
So you have checked the pump filter then?
Also need to double check on exactly which lights are flashing and which are on steady.
December 10, 2015 at 1:23 pm #433586Deeker
Yes, cleaned up the little build up that was there
Clean as new nowDecember 10, 2015 at 1:24 pm #433587iadom
December 10, 2015 at 10:33 pm #433588Deeker
Machine programme starts ok, fills up with water and starts washing
After some time the machine stops and does nothing
This continues for about 10 mins
Then the 5 lights across the top start flashing
On the right the 12h – drain light is illuminated
The door lock light is illuminated
CheersDecember 11, 2015 at 9:06 am #433589iadom
If that is the 1st and 3rd light counting up from the bottom then you have error code F05 which means pressure switch stuck on full or machine is not emptying.
If status type pressure switch check correct operation of
component;
– Check efficiency of contacts of connector J006 (commutator motor) or J7
(three phase motor) on PCB;
– Check wiring of connectors J006 (Commutator motor) or J7 (three phase motor)
/ Pressure switch;
– Check continuity of pump on connectors J004 (commutator) or J11
(three-phase), pins 4 and 5 (in case of classic door lock);
– Check wiring of connectors J004 (commutator) or J11 (threephase),
pins 4 and 5 / pump;
– Check pump filter + and wall drain outlet;
– Renew drain pump;– Renew linear pressure switch;
– Renew PCB.December 11, 2015 at 12:43 pm #433590Deeker
Many thanks for your help
