indiset wil103 error code Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › indiset wil103 error code This topic has 3 replies, 2 voices, and was last updated 13 years, 1 month ago by iepaul. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts March 17, 2013 at 10:39 am #74604 iepaulParticipant Hi I have an indiset wil103 and the four buttons and the power led are flashing rapidly along with the spin led. That is 5 horizontal led’s flashing and the bottom led of the vertical led’s. Can somebody help translate that in to an error code? Thanks. March 17, 2013 at 11:54 am #392221 iadomModerator Re: indiset wil103 error code Sadly no, that is not a recognised error code. After removing the mains plug and checking all connections plus testing the heater and the motor for insulation you are then left with a possible pcb failure if all those things check out. 😥 March 17, 2013 at 2:37 pm #392222 iepaulParticipant Re: indiset wil103 error code thanks for the reply. if the machine is left unplugged for a few hours it will work again for a few weeks. could it be a bad connection on the pcb? March 17, 2013 at 2:44 pm #392223 iadomModerator Re: indiset wil103 error code iadom wrote: After removing the mains plug and checking all connections : 😉 The electronics on Indesit are known to be flaky at the best of times. 😥 Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
