indisit 30613
  • #20997
    johno1998
    Hi Guys
    We have a problem with two indisit tumble dryers model number is 30613. We have replaced the stats on both machines , because we were getting no heat once we replaced the stats we got them to heat but 24 hrs later recalled back same problem on both machines. But we have checked the stats they are fine heater is ok, my engineer tells me when he puts the new stats in the machines seem to get very very hot at the back,is there another safety cut out on these tumble dryers. 😕 😛
    #189079
    Re: indisit 30613
    johno1998 wrote:We have a problem with two indisit tumble dryers model number is 30613.
    Are you sure about that model number? It’s not listed?
    #189080
    hf
    Re: indisit 30613
    I’m not exactly sure which one this model is but check the fan chamber has not got a rubber sleeve to the ducting which has come off therfore not pulling enough air over the heater..
    Also it may seem obvious but check the vent’s not blocked I’ve caught myself out on this one b4..
