Hi can someone help, i have a indisit w93. mod s/n 209100613—–46233300101.the light flashes to say program is ready to go, it fills with water then it gos staight to draining out, then the program dial just gos round and round, would this be the program dial fault, and how expencive is it for the part, iv had the machine for 3 years. 🙁
If you click the “Search” button above this forum you can read loads on the subject……best of luck with that problem and if you’re stuck getting it sorted, then click for help below 😉
