Indisit door lock C00085194
  • #75010
    goosegreen
    Hi, All
    Trying to replace a ‘Bitron’ door lock on an Indesit IWDC6125S
    but the lock supplied has slightly differing spacings on the tags,The one Connect have sent is a Metalflex and tags 4 & 3 are 6mm apart but 3 & 2 are 5mm. I have the instruction sheet but it only shows how to convert to the : Rold type from the original Metalflex.
    Any help appreceiated
    John
    #393589
    madangler1
    Re: Indisit door lock C00085194
    What I normally do is confirm what pin numbers go to what wires with the old lock and replicate this on the new, some times you have to rotate the plug 180 to do this but it normally always fits.
    If not can you fit spades connectors on it, in the long run its likely to last longer doing this as well
