indisit IDL 705
  • #16520
    johno1998
    Hi guys indisit IDL 705 dishwasher turns on I set the program but it does’nt do anything apart from flashing 3h and 6h after about 3 mins. Aparently the fault happened during a wash cycle ❓
    #170210
    SDR
    Re: indisit IDL 705
    it is time out draining, lay machine on lhs remove base, then un screw pump from pump cover , you will prob find a pip from fruit or something blocking impellar, hope this helps. stew 🙂
    #170211
    johno1998
    Re: indisit IDL 705
    Thanks for that I will give it a go. But would that still cause the machine to still do nothing. 😀
    #170212
    SDR
    Re: indisit IDL 705
    the first thing it does at the start of a wash is drain, if you cant hear the pump it is blocked 9 times out of 10, you can get away with taking filters out sometimes and shoving a long cable tie int sump to free the pump. the only other thing it could be but un likely is an earth fault on wash motor, causing npo but that is last resort if pump is clear. 🙂
