Indisit WIA121 Motor connector block
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indisit WIA121 Motor connector block
  • #51869
    Troffy
    Hi guys, iv’e got an Indisit WIA121 with a burnt motor connector block, can i replace the block with indiviual spade clips or is that a no no, i’m trying to get hold of a block to replace it but thinking of other options too
    cheers Ian
    #309625
    Re: Indisit WIA121 Motor connector block
    Why should there be any problem with that? As long as it’s all well insulated and cable-tied to the motor wiring plate so that no stress is placed on the connectors themselves and there’s enough length to allow the necessary movement. Might be an idea to securely number all wires for easier reconnection next time it goes wrong. (Which in the case of this model, surely won’t be long 😆 .)
    Mike.
    #309626
    C00115893 – loom – module to motor and pump.
    Only a hundred quid. That’s Indesit’s retail price with £5.99 delivery to add. I think you get 20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} off for trade so It’s probably better than paying Connect £78.30 plus vat (out of stock!). At that rate you could do the customer a real favour and call it BER 😆
    Mike.
    #309628
    Been on Connect again, Mike? There are some real world prices out there.
    😕 Masterpart’s even more.
    Mike.
    #309630
    £83.70! Ridiculous…….
    Scandalous. Don’t expect they sell many. 😆
    Mike.
    #309632
    johnnyj
    Why not use 1605743 from connect about a fiver, it should fit okay JJ
