problem help please
On off button not working
Stuck on off position. Can this be reset or is the switch u/s.
Thought id ask before going home and opening up the machine.
The power is still switched on.
Initialy the machine would not switch off at the button, so isolated power now once power reinstated it will not switch on ❗
Oh! I see now…..yes then the actual switch will be at fault.There’s nothing you can do further, call in the manufacturers and get it done under warranty now then. 😀
