Induction -Is there a method to test power output?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Induction -Is there a method to test power output?
  • #58028
    cookerfit
    Don’t know why I’m getting all these induction hobs, must look at my horoscope!
    Now have a customer who is saying her hob takes longer to heat up than it used to. ( A 4 plate hob).
    Is there a method to test power output from an induction plate perhaps similar to a microwave power check e.g temperature rise in a given amount of water.
    Cookerfit.
    #333149
    Re: Induction -Is there a method to test power output?
    should be the same as microwave check temp rise in a given time
    EFS
    Might be easier to measure the power input and work it out from that.
    Steve
    #333151
    johnnyj
    Depending on amount of ferrous compond in the pots etc, will affect the performance had loads with supposed induction frielndly pots that take ages to heat up shoved an old enamelled pot on and they worked perfectlty, JJ
