Re: Inedsit IS70C Dryer Water in heater housing
johnnyhoz wrote: customer removed heater housing and water gushed out.
How could water get into this area,? I’ve never seen this before
Its a very common, well documented fault on all Hotpoint/Creda/Indesit T/dryers of this design. 😥
The advice from cessna is spot on, give the elements and stats a good blast with a hairdryer and they should be fine, also make sure the condensor is being cleaned regularly.
