inesit wd10 not heating
  • #75516
    kevinlewis
    found fan open circuited. 230v at fan but also noticed no voltage at the heater. waited about 15 min. any advice appreciated.
    #395167
    Criscold
    Re: inesit wd10 not heating
    I presume that you have checked the thermal fuse HPTC00199364 ??
    #395168
    kevinlewis
    is that what it was fixed next to the heater.it did have a resistance but not open circuited so i thought that it was an nct. probably it is a saftey cut out. i should have checked. Thanks for that.
    #395169
    kevinlewis
    found the fault in the dry fan and resoldered the spade so the fan is now okay and running.
    The cut out was .07M ohm between the two connections. I shorted it out and all the machine would do was continually click round and round. I disconnected both connections to open circuit and the fan came ON but no heat.
    Can anyone confirm if the component near the heater is a cutout or nct. I suspect that here is another fault.
    #395170
    Criscold
    The round one with 2 spades is an NTC and the one in line to the element is a TOC/thermal fuse.
    PM your email and can send you some info on this.
    Colin
    #395171
    kevinlewis
    thanks for that. the heat fuse microtemp had blown caused by the fan open circuiting. now working fine. thanks again
