Re: Info on the Hoover Six multiposition switch
To test these:- The connector has five pads, the two outer pads 1 & 7 on one side of the board connect to the timer advance motor and should show a resistance of about 6K5 ohms.
On the other side of the board are three inner pads. The middle of these is common and a resistance should be measured between this pad and either of the outer pads. This resistance will vary as the knob is rotated, one side increasing the other decreasing.
Hope you find this useful.
Andy.
