Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › inner door on hotpoint vtd00
- This topic has 10 replies, 5 voices, and was last updated 16 years, 7 months ago by
funbobby.
September 2, 2009 at 11:57 am #48259
funbobby
Participantfor the life of me cant see how you unhook the trim from the hinge seems to be moulded round it? any little knacks? much appreciated.
September 2, 2009 at 1:02 pm #296083adv
ParticipantRe: inner door on hotpoint vtd00
cant u split the door trims?
September 2, 2009 at 1:48 pm #296084Martin
Remove the 4 screws that hold both halves together then a Swiss Army knife blade between the two halves and it should open up like a Ronseal paint tin! 🙂
September 2, 2009 at 5:23 pm #296085funbobby
sorry didnt make myself clear, door is split but the hinge is connected to the inner trim in such a way i cant see for the life of me how you disconnect it from the trim?? hard to explain but have never seen such a daft design im sure someone must have a knack.
September 2, 2009 at 5:49 pm #296086helo_75
Participantturn the hinges in as if the door was closed, lift the hinge upwards and away from the trim, quite easy really
September 3, 2009 at 8:27 am #296087funbobby
so the hinge has to be loosened off then? as it wont lift when bolted on. wish i had the thing in front of me starting to forget the bloody design now!
September 3, 2009 at 4:45 pm #296088funbobby
turns out hinge has to be unscrewed and pulled out completly then put into the trim one at a time, easy now ive done one!
September 3, 2009 at 8:22 pm #296089helo_75
Participantder/// yes, u have to take the door off first!!!!!!!!
September 4, 2009 at 10:26 am #296090funbobby
you dont lift hinge helo think you are confused.
September 4, 2009 at 3:38 pm #296091iadom
ModeratorRe: inner door on hotpoint vtd00
funbobby wrote:you don’t lift hinge helo think you are confused.
No, its you that confused all of us, we thought you had already removed the door complete with hinges which is the correct method. 🙂
We didn’t realise you were trying to remove the inner door from the hinges whilst it was still attached to the machine. :rolls: 😀
September 4, 2009 at 6:46 pm #296092helo_75
Participantof course im confused, ive only fitted perhaps 50 or so of these, some while you were still repairing tdl machines
maybe i shouldnt try and help anymore?
