Installation help
  • #67421
    Oceans
    Hi, I am currently in the process of having 4 neff appliances installed. Two ovens beneath a compact microwave and compact coffee machine all housed in larder housing units. The problem I am facing is that the installers have put an 18mm shelf above the ovens for the microwave and coffee machine to sit on.
    I did not want a gap showing between the ovens and compacts and currently there will be this showing. There is no lip on the appliances. How do I solve the problem so that all appliances seem to be flush with each other?
    Help appreciated
    #367402
    Re: Installation help
    At a guess, you can’t.
    You will likely need some sort of break there for heat dissipation. If you don’t have that then the chances are that something will go POP at some point. The heat would rise and trip out a TOC or something.
    And, that’s ignoring any weight issues.
    Best I can think of is a facing between them to give the illusion of there being no gap but it’d likely have to be custom made.
