Installation manual for Bauknecht GSI 4853 TW dishwasher.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Installation manual for Bauknecht GSI 4853 TW dishwasher.
  • #10727
    Dear all, we urgently need this manual for the circa 2002 dishwasher. The service code for it is:
    8546 853 42020.
    The search on manufacturer’s site didn’t help.
    Thanks in advance.
    #141687
    Re: Installation manual for Bauknecht GSI 4853 TW dishwasher
    You might be in trouble here – this is not a European spec machine, so can’t find any reference to it……
    What is the actual problem, as apart from hanging the decor door, installation is generally pretty straightforward?
    Penguin45 wrote:You might be in trouble here – this is not a European spec machine, so can’t find any reference to it……
    Thanks you.
    I need to know the maximum distance from the sewerage pipeline-as supposed to be limited by the pump performance.
    #141689
    Dave_Conway
    As a general rule, the waste pipe should be directly behind or as near as possible to the dishwasher and at least 2/3rds the height of it.
    It’s also best to use a standpipe installation as opposed to the usual sink trap connections as these block to easily and cause syphoning problems.
    #141690
    ali-p
    we have found the ifu – but there is no recomendation for a maximum distance for the drain hose.
    As Dave sugests, the shorter the drain the better, but if you would like a copy of the IFU please pm me for details
    Alister
