Hi i have a whirlpool american fridge freezer. the solenoid failed and decided to buy the generic input and 2 out puts from your site. obviously as the commentary suggested there is a bit of fiddling required.
there are 3 differences
one side has a diffferent electrical spade to error proof assembly…i’m sure i can change to make do
the inlet diameter on the origonal pipe to the fridge is about 12 mm…expect i can buy fittings to step it up or buy a new water inlet pipe..do you sell?
but the water supply pipes to the ice maker &water were designed to fit into the origonal solenoid and then hand tightened with a nut..are the fins inside the ‘generic’ output sides adequate to hold the pipe…if not how do i step it up to an appropriate diameter to slide over the outside of the pipes
thanks in advance
