Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Installing a (Range ) Cooker by a window?
- This topic has 11 replies, 5 voices, and was last updated 18 years, 3 months ago by
teresagreen.
January 1, 2008 at 11:40 am #33323
teresagreen
ParticipantI was hoping to buy a rangemaster 90 cooker in the next few days-but I may have a problem. The kitchen it will be going into is l shaped. On the short wall that is the only place we can put wall cupboards- and on the long wall it is nearly all in front of a long rectangular window. I think i read somewhere that it is best not to put a cooker in front of a window-but we have no choise-also do you have to install a exractor hood over them-this wont be possible?
January 1, 2008 at 12:13 pm #238295kwatt
KeymasterRe: Installing a (Range ) Cooker by a window?
The hood is optional Teresa, not required as such just nice to have as it (if fitted correctly) removes a lot of steam and odours.
In front of a window for a cooker, especially gas, isn’t great mainly because if you have a gas cooktop then the burners (the small ones are worst) may well get blown out if the window is open, even just a little. And, obviously, steam and cooking odour can be blown back into the kitchen which isn’t ideal.
HTH
January 1, 2008 at 5:43 pm #238296wsts
ParticipantThere is no regulation to say you cant have a cooker in front of a window, obviously there if for curtains behind it though, are you having the 90 with the glass lid ?
January 2, 2008 at 12:18 am #238297teresagreen
ParticipantRe: Installing a (Range ) Cooker by a window?
no,not a glass lid,and no curtains
January 2, 2008 at 12:19 am #238298teresagreen
Presumably if i just keep the window shut when the gas hob is on it would be ok.
January 2, 2008 at 12:26 am #238299Penguin45
Trouble is, after a while, you’ll get comfortable using it, it’ll become part of the furniture and one day……. you’ll forget.
WSTS’s point is that the model with the glass lid would, with the lid up, act as a wind break.
January 2, 2008 at 9:26 am #238300gegsy
teresagreen wrote:Presumably if i just keep the window shut when the gas hob is on it would be ok.
An openable window may be a requirment re- ventilation of appliance.
😕 Consult the user manual ❗Greg
January 2, 2008 at 6:30 pm #238301teresagreen
ok- i will ring up rangemaster and ask.
January 3, 2008 at 11:34 am #238302wsts
gegsy wrote:
teresagreen wrote:
Presumably if i just keep the window shut when the gas hob is on it would be ok.An openable window may be a requirment re- ventilation of appliance.
😕 Consult the user manual ❗GregIn the gas regs an openable window is always a requirement…. but it doesnt have to be open, otherwise they would ask for permanent ventilation.
January 3, 2008 at 7:08 pm #238303gegsy
Sorry,wsts is correct 😳 it IS required OR an alternative opening which opens to the outside air.
I was confusing it with the permanent vents that may be required depending on room volume. 🙂Greg
January 3, 2008 at 7:23 pm #238304teresagreen
I spoke to Rangemaster today,they confirmed it would be ok as long as the window was sealed(no draughts) which it is.We have a utility room next to the kitchen,so I could just open the window on that for extra ventilation.Thanks for all your help.
January 6, 2008 at 11:27 am #238305teresagreen
After speaking to a kitchen planner and input from OH ,we decided that aesthetically, it might not look quite right to other people in front of the window, (if we ever had to sell the house,we dont plan to,but who knows),so have re jigged the storage and put it on the short wall. We need to buy a hood now to finish off the look ,so just off to read the section on here about extractors. I know Range master do a black one for about £400 but hadnt planned to buy one.Need to do some more research.
