Installing of HYGENA APL3120 built in single oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Installing of HYGENA APL3120 built in single oven
  • #44924
    stresshead
    Hello,
    I’m a newbie to this forum and would really like some advice.
    I sold a used new Hygena oven APL3120 that was taken out for a kitchen reburbishment. The oven had never been used and seemed to be in fully working order at the time.
    The buyer of the oven is reporting that when he installed it, there is a direct earth on both elements?
    Can anyone shed some light on what this means? and a solution please?
    Many thanks in advance 🙂
    #282963
    smartin
    Re: Installing of HYGENA APL3120 built in single oven
    tell them to check the way its wired in to the terminal block after they have unplugged it of course.
    #282964
    stresshead
    Thanks for such a speedy response smartin! 😀
    I will call them tomorrow to get more info and report back.
    Cheers
    #282965
    spimps
    Just another thought ,it could also mean there is an earth fault ie leak to earth when the element is tested with a megger which could have sent the rcd trip out.
    If the oven has been stored some where for a while the oven elements do tend to absorb damp and then will set an rcd trip off.They can be dried out sometimes but it’s not always 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
    #282966
    Specialist01269
    Totally agree with Spimps, unfortunately most sparkies don’t realise that Elements will soak up damp if left in an unheated area.
    #282967
    stresshead
    Thanks again for your replies.
    I have heard back from the buyer and he states:
    These elements are both removed from the oven and are “going to earth” This means that when I use my “multi meter” for checking the continuity (circuiting), one of the circuits is going to earth (short circuiting)
    Both the top and bottom elements have two separate element circuits.
    He has taken photos of the elements which are supposely not available? I will upload this when I reveive them.
    Any ideas what the next step is?
    #282968
    Grill element is p/no 11239726. Base element is 112358295. spares@ukwhitegoods.co.uk will be able to supply for you.
    stresshead
    Many thanks Penguin,
    Do you have any idea how much both the elements are?
    #282970
    spimps
    stresshead wrote:Many thanks Penguin,
    A trick is to pop them in a friends oven and “cook” them for 40 minutes or so a@180C this MAY expell the moisture so you can check with the meter again and may be able to rescue them for use.
