Instruction manual Indesit WE16 washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Instruction manual Indesit WE16 washing machine
  • #9190
    Hi, Maybe you can help me. My Indesit WE16 Washing machine will no longer pump out the water and comes up with code F-05 in the display. I no longer have the instruction manual and I cannot find the product code to look it up in the site you recommended http://www2.merloni.com/indesit/_pdf/manuals/
    Can you help me with a link to download an instruction manual for this machine or with a suggestion what to do or what the code means ?
    Rob
    #132893
    Re: Instruction manual Indesit WE16 washing machine
    Hey ho, great site !
    Found the answer, it was the filter which was blocked. I removed the bottom front panel, unscrewed the large filter screw, drained the water (using a pizza tin, too low for anything else) and found a bit of T-shirt in the filter blocking the water.
    Still would like to get a manual.
    One more thing which is strange. The writing around the dail has become undone and can be wiped off, most of it is already gone, luckily my wife remebers what is what because you can no longer read the numbers and the pictograms. Very oddb because the same thing has happened to the word Evolution but not to the other printed words on the from, like on/off, mode or select. This has been for a long time and happened shortly after we bought it.
    Does anyone know what it should say around the dial ?
    Rob
    #132894
    wildrover wrote:Still would like to get a manual.
    Using their website, select the same product code as is listed at the back of your machine.
    wildrover wrote:Does anyone know what it should say around the dial ?
    No, but if the manual doesn’t show the dial markings, we could supply a new dial by emailing us at spares@ukwhitegoods.co.uk
