Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Insulation Tester
- This topic has 9 replies, 5 voices, and was last updated 16 years ago by
mjhservices.
March 12, 2010 at 8:14 am #53183
mjhservices
ParticipantDoes anyone know the difference between an insulation tester costing around £80.00 and £300.00? They both read to do the same?
Regards MarkMarch 12, 2010 at 8:54 am #314749Martin
ParticipantRe: Insulation Tester
mjhservices wrote:They both read to do the same?
Like the difference between a £150 washing machine and one that costs £550 I should imagine? 😕 By cheap, you get cheap, stump up to the top tier and you get a tester that is far more efficient, reliable and above all resilient to the rigours of a long and hard life. 😉
March 12, 2010 at 8:40 pm #314750derek
the difference is the values you get on the screen! and how accurate they are! ie the £80 one will be so inaccurate and have less features than the £300 one
go with a fluke every time or megger if you want decent IR test results, the same is said with multimeters.
in saying all that if its just for blatting a 2.5mm or 1.5mm 3 core on short cable runs it should be ok!
hope this helps
March 13, 2010 at 1:07 am #314751leavemetogetonwithit
I got one second hand in as new condition for £40 on e-bay. The new price is about £400! It’s a beauty. I take it in my shoulder bag when I leave my bike outside the supermarket, ’cause I’d be gutted if it got nicked!
Mike.March 13, 2010 at 1:13 am #314752cornwell40
Got an 80 odd quid one recently as a spare, cos I had one half inched.
Chinese one from CPC in a lovely yellow rubber case.
Must admit it is every bit as good as my Metrahit 16i which I originally got for £350, got a brand new replacement off ebay for £120.
Longevity I’m not sure about but features etc its good.
TCMarch 13, 2010 at 1:27 am #314753leavemetogetonwithit
Snap! Mine’s a Metrahit 16I too. Thought they were a bit rare over here being German. Very sad to hear that it’s not better than a Chinese one!
Mike.March 13, 2010 at 7:40 am #314754derek
lol 😆 fluke or megger!!! everytime!
your £80 quid ones dont comply with uk regs check the ce markings nor do most of them come with fused leads (uk regs)
nor do they have auto discharge and most decent ones now are multi units with ohms as well
i have worked on a lot of sites with inspectors who will not allow readings from anything but fluke or megger (or equivelent) and must be calibrated with the correct leads!
you can buy a decent megger (second hand from ebay for £80) infact i have a couple and fluke multimeters if you want them?
i no longer use them as i have 2 17th edition units! will post them to you if you need them
March 13, 2010 at 7:54 am #314755derek
CPC TESTER £89+VAT
* Large LCD, Dual display with bargraph & backlight
* 125V, 250V/500V/1000V test voltage selection for MΩ testing
* AC/DC Voltage measurement
* Low Ω function for testing connections
* Data hold
* Large “Test” button and output Voltage lock
* Continuity buzzer
* Over range indication
* Low battery warningTechnical Data
Function Range / Resolution Best Accuracy
AC Voltage 750V / 1V ±1.2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg±10d
DC Voltage 1000V / 1V ±0.8{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg±3d
Resistance 40Ω, 400Ω / 0.01Ω, 0.1Ω ±1.2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg±3d
Insulation Resistance 4M, 40M, 400M, 4000MΩ/1KΩ-1MΩ ±2.0{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg±6d
Test Voltage & Current 125V, 250V, 500V, 1000V & 1mA Nominal
Continuity Test <35Ω Active sound level, <200mA test current
Power 6x AA Batteries
Safety IEC1010 1000V CATIII ±(1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg+2d)
Dimensions (WxHxD) 92 x 200 x 50mm ±(1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg+2d)
Weight 700g ±(1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}rdg+2d)
FLUKE 1503 224.22+VAT* INSULATION TESTER
* Insulation Test Resistance:0.1 M to 2000 M
* Insulation Test Voltage:500 V, 1000 V
* Insulation Tester Type:Insulation Tester
* Approval Bodies:CSA, TUV
* Battery Size Code:AA
* DC Test Voltage Range:500 V, 1000V
* External Depth:50mm
* External Length / Height:203mm
* External Width:100mm
* IP Rating:IP40
* Input Impedance:3Mohm
* Insulation Measuring Range:0.1MR to 2000MR
* Max Input Voltage:600V
* Max Operating Temperature:55°C
* Max Storage Temperature:60°C
* Min Storage Temperature:-40°C
* Min Temperature Operating:-20°C
* Resistance Measuring Ranges:20R, 200R, 2kR, 20kR
* Safety Category:EN61010-1 CAT IV 600V
* Voltage Measuring Ranges, AC:600 V
* Voltage Measuring Ranges, DC:600 V
* Weight:550g
Insulation resistance
Fluke 1503 Fluke 1507
Test Voltage = 50 V
Ranges 0.01MΩ – 20MΩ, 20MΩ – 50MΩ
Resolution 0.01MΩ, 0.1MΩ
Test Current 1mA at 50kΩ
Accuracy ±(3{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 5 digits)
Test Voltage = 100 V
Ranges 0.01MΩ – 20MΩ, 20MΩ – 100MΩ
Test Current 1mA at 100kΩ
Test Voltage = 250 V
Ranges 0.01MΩ – 20MΩ, 20MΩ – 200MΩ
Test Current 1mA at 250kΩ
Accuracy ±(1.5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 5 digits)
Test Voltage = 500 V
Ranges 0.1MΩ – 20MΩ, 20MΩ – 200MΩ, 200MΩ – 500MΩ 0.01MΩ – 20MΩ, 20MΩ – 200MΩ, 200MΩ – 500MΩ
Resolution 0.01MΩ, 0.1MΩ, 1MΩ 0.01MΩ, 0.1MΩ, 1MΩ
Test Current 1mA at 500kΩ 1mA at 500kΩ
Accuracy ±(2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 5 digits) ±(1.5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 5 digits)
Test Voltage = 1000 V
Ranges 0.1MΩ – 200MΩ, 200MΩ – 2GΩ 0.1MΩ – 200MΩ, 200MΩ – 2GΩ, 2GΩ – 10GΩ
Resolution 0.1MΩ, 1MΩ 0.1MΩ, 1MΩ, 100MΩ
Test Current 1mA at 1MΩ 1mA at 1MΩ
Accuracy ±(2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 5 digits) ±(1.5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 5 digits) / >2GΩ: ±(10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 3 digits)
Earth Bond Resistance Measurement
Range 20R, 200R, 2kR, 20kR
Resolution 0.01Ω, 0.1Ω, 1Ω, 10Ω
Accuracy ±(1.5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 3 digits)
AC/DC Voltage Measurement
Range 600 V
Resolution 0.1 V
Accuracy ±(2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} + 3 digits)
General Specifications
Operating Temperature -20
Batteries 4x AA batteries. Can perform 1000 insulation tests.
Protection Standard IP40
Dimensions (WxHxD) 100
Weight 550
NOW I KNOW WHAT ONE I WOULD BE USING ON LV AND HV!!! LOL
😆 Approval Bodies:CSA, TUV!!!March 16, 2010 at 11:08 pm #314756leavemetogetonwithit
derekwatt wrote:Approval Bodies:CSA, TUV!!!
Well I dunno who TUV are but that Child Support Agency lot – there’s just no escapin ’em.
Mike.March 17, 2010 at 1:46 am #314757derek
http://www.tuvps.co.uk/home_en/industri … ification2
http://www.csa-international.org/Defaul … ge=english
http://www.ul.com/global/eng/pages/fluke and all decent meters are tested and have these markings!
yes i know all about the bloody csa!! 😈
