Insurer sending video repair company to asses tumble dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Insurer sending video repair company to asses tumble dryer
  • #96386
    cypher007
    My insurer has asked Bevalued to send someone round to asses our Siemens heat pump tumble dryer. They have contacted a video repair company. I’ve checked there website and the closest they get to white goods is microwaves.
    my insurer has said they may repair the dryer, well I’m not keen on them having a crack at it.
    can I insists only a Siemens approved engineer fixes it?
    #463204
    do you want to tell us the problem you are having.
    not sure if you can insist Siemens do the repair but I think you should be able to expect a suitably qualified engineer
    cypher007
    Already covered the problem in my other post.
    basics are went on holiday came back and both Miele washing machine and Siemens tumble dryer are acting up on psu.
    Miele has been repaired on warranty, new psu logic card.
    Siemens is still broke. Will run for between 5mins and nearly 2 hours depending on what mood it’s in. Then display goes off dead nothing. Wait 2-3 mins then it will let you turn it on.
    #463206
    I see did not connect the two due to duplicate posts. one reason why adding multiple posts causes confusion
    well since the power supplies in the dryer are similar to a video they may well have enough experience to diagnose a mains surge fault
    cypher007
    Video repair company visited. Just looked at the condition of the machine took some pics. I said what it was doing and he said yeah there’s been a lot of storms in the area. He said he would send the details to the insurer and see if they want to repair or replace.
    Now bearing in mind they don’t normally repair tumble dryers, and the fact no one has actually tested all the other electronics that are in the machine e.g. large capacitors and mains filters not to mention a compressor, I think I will be contacting the insurance ombudsman if they want a video repair company doing it.
    #463208
    just wait and see for now
    we know its board problem and videos have boards too so can suffer the same problems. suppressor will be fine as will large caps this problem is a board power supply problem as far as I can see
    you can find the board prices here
    https://www.siemens-home.bsh-group.c…t/search-parts
    then you will have an idea of the part prices involved
    cypher007
    Cheers mate. Yeah I found the board and it was £300 without fitting. Or 230 euros from Siemens Germany. Hmm being in the Eu doesn’t seem to be working for us.
