Hi all
Can any one give me some tips on how you are supposed to change the thermostat in these things?
It is an integrated fridge – I have managed to pull it out of its position (after dismantling half the kitchen to gain access 😡 ), I have tried removing all the screws from the side panel (1 on top and 2 underneath – also the 3 holding the base on) thinking that I can then pull the panel off and get to the end of the capillary tube but try as I might I can’t get the side off 👿 and can’t see anything holding it on either so would greatly appreciate it if someone could tell me the trick to these and maybe even supply a service manual as I am currently having no luck at all with it. :angry4: :bang:
Thank you
Jeremy
