I need advice to replace my whirlpool 50/50 integrated fridge freezer as it’s not cooling as well as it should and has a buildup of frost even in the fridge section. The replacement needs to be 57 cm wide and the door hinge on the left unless it comes with the option to change the hinge side.Four freezer compartments, three shelves in the fridge with another 3 trays in the door would be ideal (that’s how the existing fridge is).
All 50:50 split will have the same set up. Can you post up the model number of the existing appliance please so I can check whether you have a fixed or sliding hinge system. Door reversal should not be a problem with either set up.
Unfortunately the sticker with the model number has been rubbed off. It uses a couple of rails to attach the door to the fridge doors to slide along. Hope that helps.
That’s good it means you have the more popular sliding system.
Every built in manufacturer produces a 50:50 sliding hinge fridge freezer. It just comes down to your budget and the door and shelf configuration you prefer.
Best reliability will be Liebherr but also among the most expensive. For a good all rounder without paying the earth and In no particular order Hotpoint, Bosch, Zanussi and Beko.
