Integrated Bosch dishwasher – recirculating pump change
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Integrated Bosch dishwasher – recirculating pump change
  • #85542
    HandyTimo
    Morning,
    Changed the whole circulation pump entirely apart from the pump housing. When i run the machine the impeller seems to be jamming the motor. Deassembled and reassembled the pump countless times and no luck. Is there a trick I’m missing when screwing the impeller into the pump? The spacer is the correct way round and the impeller will not screw any further.
    Any tips greatly appreciated,
    Tim
    #428831
    nomadPaul
    Re: Integrated Bosch dishwasher – recirculating pump change
    When you screw the impellor up and it tightens , can you rotate the impellor or is it jammed and unmovable ? It sounds like you may have the wrong sealing/impellor kit.
