Integrated Bosch washer dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Integrated Bosch washer dryer
  • #103279
    suedehead1
    WKD28352GB/01 , it comes up E12 the pump was making a terrible racket so assumed it was that, replaced the
    pump still comes up E12 near the end of the program any ideas welcomed
    #492470
    on a google search the fault come up as
    In some Bosch washer/dryer models, an E12 error code can indicate a problem with the communication between the control board and the dryer heater sensor.
    all this could mean is a faulty sensor or a broken wire
    kaibart
    I’ve attached pic of e12 error no good reading either motor or pcb expensive repair
    #492472
    Kentish
    Did changing the pump quieten it down? The drain hose on these machines has a nasty habit of blocking at its internal elbow. I haven’t yet managed to clear one due to the shaping and internal diameter changes, so I just change the drain hose.
    these are Smeg machines, and the Smeg parts through Aswo are way cheaper than the Bosch labelled identical parts.
    #492473
    suedehead1
    Hi the pump made it quite but on return i noticed the brushes were worn, an amateur mistake
    #492474
    we all get days like that lol
    almost did a similar thing yesterday. had a dead Beko washer dryer thought D7 failure. undid screws on board and upended machine. was just about to remove board when I thought ” wonder if the socket is live”. Well it wasn’t, the clien did not know the bank of 4 switches controllled various appliances around the kitchen and the switch was off
    eventual fault was a button and lint at the sink end of the outlet
    came out the job to a parking fine as the ticket had fallen off the dash. have appealed but if i fail its only £25 and its liverpool council so am not fighting a private parking pirate
    suedehead1
    £25 cheap for a parking ticket, i use one of those voltage pens to check if its getting electricity I have had the same thing before
    #492476
    suedehead1 wrote:£25 cheap for a parking ticket
    yes I thought that, was expecting at least £50. would have been if it was a private car park
    have appealed it so lets see what happens. if i lose am still in profit for the job
