Integrated condenser dryer?
Home Forums Public Support Forums Buying Advice Integrated condenser dryer?
  • #90245
    Harmonyclara
    I currently have a vented tumble drier with a hose through the wall to the outside, but can’t use it much as it shrinks my clothes. I want to replace it with a pump heat exchange(I think they’re called) condenser drier with lots of delicates settings, and much better economy.
    Can I site it under the counter behind a cabinet door in my fitted kitchen???
    #444176
    Re: Integrated condenser dryer?
    I think you mean a heat pump dryer and you’d probably be best to read this first before going there:
    http://www.ukwhitegoods.co.uk/help/buyi … s-worth-it
    And no, no condenser or heat pump dryer which is also self condensing can be installed that way currently, far as I am aware there are no integrated condenser dryers sold in the UK presently.
    If you try it you’ll likely have the machine overheating and cutting out due to restricted airflow and/or condensation forming on the cabinet door as well as the floor in front of the dryer.
    don
    White Knight currently have a range of integrated vented dryers link here As K rightly says no condenser ones I’m afraid.
    Don
