Integrated dishwasher ADG-7450
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Integrated dishwasher ADG-7450
  • #57528
    x-celerate
    I’ve had this dishwasher for several years but it suddenly stopped washing the dishes. Water fills at the base. The spray arms / filters are not blocked.
    Initially the fault code was three flashes but this disappeared after unplugging the machine. I also checked resistance on the NTC , it was reading around 13 kohms when the machine was off.
    I would interested to know if anyone knows what the fix is.
    #331423
    baldy55
    Re: Integrated dishwasher ADG-7450
    Problem could be your circulating pump. If you look at circulating pump does it look like a bigger version of drain pump. These give alot of trouble and are replaced with a revised circulating pump. The revised pump has got a capacitor attached to the side and if this is the style of pump the capicitor may need to be replaced?
    #331424
    clivejameson
    Have a look HERE
    #331425
    x-celerate
    Thanks for the advice. Pump replaced. Fault fixed.
