Integrated F/F Hinges Are These Makes The Same Ones?
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Integrated F/F Hinges Are These Makes The Same Ones?
  • #82221
    laurenceuk
    Bosch F/F KIV38A51GB/03 door hinges? Connect 5031688478527
    AEG Freezer G91850-4i door hinges?
    Connect 5045171938108
    Connect 5045171999192
    Are the hinges attaching these doors the same, from memory they look very similar.
    Thanks in anticipation.
    Laurence
    #419208
    Re: Integrated F/F Hinges Are These Makes The Same Ones?
    I’d visit the Bosch web site and double check the part number first if I were you.
    #419209
    laurenceuk
    Thanks Martin,
    The Bosch number is correct.
    But because the AEG hinges look so similar (from memory – especially both having the plunger where the spring pops out causing the problem), I was wondering if the AEG might be badged or just using hinges that cut across manufacturers. AEG very expensive.
    Laurence
    #419210
    laurenceuk
    FYI the above hinges are deffo not compatible. The fridge or freezer door’s hinge bracket has different hole centres.
    Laurence
